RNS-D Refitting Question
Just got my radio extraction keys for the RNS-D, prior to moving the fog light switches from passenger side to drivers side, to make them easier to access (an idea by notorious in this thread).
I have a couple of questions before I do this for real. 1. I tried the keys and the unit slid out effortlessly, but seems a bugger to replace. Tried it several times but bottom doesn't want to go in fully. There appears to be a large rubber bung on the back of the unit, close to the bottom. Would this be causing it? 2. Do I have to disconnect the RNS-D to work on the wiring for the fog lights, and if so, will I need the radio code afterwards? |
They should go back in easily, the bung fits into a circular hole at the back of the frame and helps secure it without vibration.
If it won't go back easily you've probably got some cables in the way - there's plenty of them! (I've had mine in and out several times a day in recent weeks, it's currently about 1cm out as some new cables I added need routing more carefully. :o ) If you disconnect it you will need the code. |
