Battery Change Time. . .
Recently been finding that as I'm only using the 8 for the odd evening or weekend the cold weather is making the need to either run it more regularly to charge up the battery, or change the pretty old battery for a new one.
Anyways I've decided to bite the bullet and get a new battery before the weather turns really bad (or scottish as we say down here in the south lol) Ive done some research and plumped for THIS one which has an awesome 110Ah capacity and a cold cranking amps of 920 which is good and high. After a bit of playing one battery shop off against the other I've managed to get it for £99 including Vat which I don't think is too bad for a very high performance battery. I wondered how everyone else is finding the cold weather affecting their battery charge, and also who else has changed battery and to what Batteries at what sort of prices? |
Just checked and it's a Bosch 88Ah "Silver" bought in October 2003! I think I paid about £30 at Costco for it....:o |
I got new one last year, bought cheapest at local shop that came with 3 year warranty for around £70. They had some cheaper ones with 2 year warranty. Don't remember make or details.
Mine has a genuine VAG (Moll) battery, never had any issues with starting, even when left for three weeks without starting. Mine's garaged though.
Just out of interest, are there any issues with throttle body reset after battery power has been interrupted? |
You are advised to change the battery within a short time of disconnecting - I did this and all I had to do was re-enter the RNS-C radio code, everything else has worked perfectly. Car is now turning over quicker and starting fine +++
Resurrecting this post:-(
Just changed my battery for a Bosch bigun' and the car starts great and even my sat nav now works as it should (it was around 300 metres out and thanks to Limoncello for trying to help out :)). I bought it from Halfrauds and included fitting and he whipped the old one out and the new one in within a very short time frame. Now the issue - it feels like it is in limp mode:( When idling, it rocks the whole car and when you drive and put your foot down it really struggles to surge forward, even when dropping down a gear or two.... Any suggestions will be greatly received as off on holiday on Friday and would prefer it to work correctly :-( Cheers in advance ;) |
was it ok before the battery change?
I suggest looking checking for fault codes in ECU and possibly do basic setting. It should self adapt after power being disconnected but it might take a while. I always do basic setting myself after disconnecting battery. Or it could be something not related to battery change. VCDS scan should give should show if something is wrong. |
Problems idling and moving forward
This sounds like a misfire to me, how longs it been going on?
