-   D3 - Engine Bay (https://forum.a8parts.co.uk/forumdisplay.php?f=44)
-   -   4.2TDI radiator fan running constantly (https://forum.a8parts.co.uk/showthread.php?t=5597)
paulrstaylor 6th November 2012 03:56 PM
I returned home after a week away and my car has developed an issue, basically the radiator fan is running constantly and continues to run for about 30 seconds after I stop the engine.
A quick scan revealed the following code:
Code:
                Address 01: Engine      Labels: Redir Fail!
Control Module Part Number: 4E1 910 409 A    HW: 4E1 907 409
  Component and/or Version: 4.2L V8TDI  G000AGMª0070
          Software Coding: 0011773
            Work Shop Code: WSC 00503 503 81333
                      VCID: 22400330FD210608171
1 Fault Found:
006400 - Coolant Fan Control 2
              P1900 - 001 - Open or Short to Ground
I am suspecting an electrical issue, bad contact or corrosion or possibly a faulty module, but before I start taking things apart I wondered if anyone had come across this before?
47p2 6th November 2012 08:35 PM
Could it be caused by low battery voltage?
ainarssems 7th November 2012 05:45 AM
Sounds like a short in fan control module. Happens to lot of VAG cars across the range.
paulrstaylor 18th November 2012 03:58 PM
Well as suggested it was the fan/control module (4E0 959 455 H), replaced with a new one and all back to normal :)
