Yup, you can just disconnect it. I've had to do that on both my S8's.
Is yours PF or FL? Easier to do on PF.
Easiest way to check it's that is to turn the ignition off then press the "Rest" button which will fire it up.
(also a good way of testing that you've opened up the correct connector to disable it)
