Originally Posted by The_Laird
Ian, we shouldn't need to tell you that photos are a must!
I expected this....
but not within 6 minutes of posting...
Here you go:
Extended leather, deep useful door pockets and handy flip up lid at far end for smaller items:
Comfort seat controls. Far too many controls for a 1 to 1, so the far end 4 way round control is a menu control for many many fine adjustments
Night vision and all weather headlights control
Armrests lift up in parallel, level. Not hinged from the rear.
Alcantara roof, sunroof, and you can just see the ambient light strips at the top of the B pillars:
DVD changer, for when 1 movie on tap is just not enough... and cold air inlet for chilled glovebox viewable at the rear.
MMI and HVAC controls. All neatly laid out, and easily accessible when resting your write on the gear level as per Audis design....
Massage functions. Various ones, and varying intensities. Really very good ! much better than the D3 version that just wiggles the lumbar support about a bit...
Seat fine adjustment menu....
Main 3G Plus menu:
Main DIS. Values were reset when I bought it. 200+ miles later and showing 35 mpg. Not bad at all
Ever wondered what a D2 looked like through infrared night vision? No probably not, but just in case:
Reversing camera, same as D3 from what I can see. Larger screen on D4 is good though.
Drive Select. Lots of fine tuning if you want a slightly different ride:
Main car settings menu:
Leather dashboard. Moo. Perfectly done too. I've seen a few D3's with slightly wobbly stitching...
Passenger side wider shot:
Interior lighting menu:
Driver Assist menu:
Cold feet ? Let me fix that for you sir....
Audi Privacy Handset, has phone book and O2 connection via rSap from my phone in the door pocket so the passenger can make a perfect quality call with external aerial in some privacy.
Heated steering wheel button has moved here where the easy entry / exit used to be. Easy entry/exit is now an MMI setting that is stored per user memory
Children in the back who have video consoles each, and also want to smoke? Sure. Er, we can do that too it seems....
Rear climate / heated seat controls. Visually this looks like a flimsy armrest that plonks down onto the seat, but I now see its a very well constructed solid fitment and works really well
And finally the boot. Yes, shallower than the D2/D3, but does feel wider and more accessible. Two cubby holes either side, and also a space save spare wheel underneath. The auto boot action is incredibly smooth and quiet.....
