No im waiting for the 3rd set of av leads to turn up before i can do that. In truth i didnt know that was an option until i got a copy of the install pins on the av1 and 2. And there was the pins needed for tv out so ordered the 3rd set straight away. Should be monday or tuesday i hope!
As for pics there isnt really much to it.
I ran the cabling from the units (single multicore) down behind my seat back plastics to the bottom.
From the bottom i left a slight loop for seat movement so it doesnt go tight. Where the rear vent is under the seat is a seam where 2 bits of carpet meet so i bedded the cable into that and out under the chair runner and up to the side sill covers.
From there back to the rear seat, pop of the rear sill trim and there is a lovely hole that runs through to the boot in the bottom left of the seat back as you look in from the rear.
From there just route all cabling behind the left side trim cover to the tv unit. I took my power from from the boot 12v socket. Im not going to hardwire it.
That was for the passenger side.
The driver side was the same upto the point of getting to the back seat. From there i routed it across/under the rear seat so it could link with the rca's from the passenger side leads.
