I've never heard of an A8 tiptronic change failing but I guess its not impossible. That shifter certainly looks very similar to an A8 one, although it could be cheaper to buy a second hand whole gear lever than to source those parts new....
The tiptronic shift is literally 2 wires connected to (effectively) 2 push to make contacts which connect directly to 2 pins on the gearbox ECU in the plenum chamber under the bonnet.
I fail to see how the wiring could have 'gone faulty' unless some did a botched attempt at changing round the way it works (so pull back goes up gears instead of down) in which case I guess the switch is the only possible culprit....
Unless there is some way to code out the tiptronic function on the ECU to prevent it recognising the switches, but then I wouldnt expect it to get as far as the '12345' in the display....
How odd... !
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
