Edit: I'm half asleep - This is for D2, not D3, but the concept should be the same - I'd look at basic settings for a start
The outside air flow flap motor is under the bonnet.
At the rear of the engine bay is a meshed plastic cover held on by 3 screws.
Remove it, you will clearly see the flap.
On the side of the flap is a square box say 3 inches by 2 that houses the motor. Couple of cross head screws to remove the cover, and probably 2 more to change to the motor.
But, this probably wouldn't cause your issues as it only chooses recirculation or not, rather than air temp.
If you are getting the wrong air, in the wrong place, run output tests using VCDS and it will force the climate module to learn the positions of all the flaps. In output tests, with 000 showing in the box, just hit go. It will start at 50 (i think) and count down to 0, moving all the flaps. When at 0 it is done.
It will likely improve the issue massively, and/or may flag up another motor that is actually at fault
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
