FL windscreen washer problem
coming up to MOT time and no doubt it will fail if both sides don't work ....
drivers side ok , but just a few bubbles on the passenger side so tried to unblock with an ultra fine needle....no change
so unclipped the end and noticed the twin wires connected to it so pulled off the plastic tube and operated the washer switch ......drivers side as before and strong gush of liquid out of the open passenger side tube
well, I already knew the pump worked , question is what are the electric wires for ? only thing I can think of is that there is a switch in the end fitting to stop the liquid from running back
so maybe a new fitting on the end ? any suggestions ? any part numbers?
