MJ: There is a very full write up from Audipage which is in the sticky at the head of this section - wouldnt want you to spend time duplicating work already done.
HP: With regard to weather/damp affecting the switch function, I gave my connector a good clean (even tho it looked OK) and it did, as I said earlier, help - for a few hours! Why cleaning it did that when the fault lay in the switch body is a mystery to me.
