I have seen the thermostat replace with just slacking the cam belt. I guess you would still need the crank pin and cam locking bar when torquing it up again? But I suppose if you're DIYing yourself it should be ok and then replace the other parts at another time.
Just out of interest, what actual peak temps are you getting?
Matt
