When I got my A8 D2 I noticed that there was a slight noise coming from the driver's door when going over bumps on the test drive. It was a kind rattle/shaking noise. Very slight, but it is enough to bug the hell out of you.
I also noticed when checking the car for purchase that there were a number of door clips missing. In fact, the bottom of the door card could be pulled back and forward it was so loose. So I thought that I knew that I could fix that when I got home with a few new door clips from our sponsors.
Now that the door clips are in place, the door card doesn't move on the door - as it should be - but I still get an annoying sound from near to my right ear when going over a rough surface. My ears are now so attuned to it that I am sure that above all the other sounds I can hear something similar from the rear (n/s) passenger door too but I may be just imagining things.
When driving, if I reach up and grab the top of my door with my fingers (door obviously closed when driving), I can, with a bit of force, push the the top of the door frame enough (must be millimeters if not less) to create the same sound that I guess I can hear when driving.
So the question is, does anybody else have any experience of this?
Does anyone think that the door would need adjusting at the hinges to create a tighter fit?
Would anyone recommend an Audi dealer to look at it? I know the labour will be high but......
Has anyone had this issue and tried to twist/bend the door frame slightly to create a better fit?
Any help/sharing of experience would be appreciated.
I did a search and found a link on the forum to door fitting but it was for a D3
TIA
Dean
Dean
2002 A8 D2 S8 FE -
"Red Dwarf" - Misano Red - Platinum/Silver Interior, PDC, Sat Nav Plus with BOSE and hidden Dension Bluetooth, Multi-changer, Heated Front Seats, Bi-Xenons, FE Wheels, Phone Prep with Nokia 6210, Detachable Towbar, Rear Blinds, S8 plate but no other optional extras
2002 A8 D2 2.8 Quattro Sport -
"Big Red" - Tornado Red (Special Order) - Twist Interior, PDC, Passenger Memory Seats, Symphony II with BOSE, Heated Front Seats, Bi-Xenons, Auto-dimming Mirrors, 20" FE Wheels, Servotronic Steering
