View Single Post
Old 23rd January 2017, 11:24 AM
The Webasto coolant heater was fitted to all D3 A8 diesels, and the Q7 4L also.
And the A2 diesel, and likely some others.
It is designed to bring the engine up to temp rapidly rather than waiting for the diesel block to eventually do its thing. It shouldn't need to run for more than about 10/15 mins really.
Optionally, although not available in the UK brochures, you could get auxiliary heating which uses the same webasto heater, but has a second battery and water pump to allow the car to pre heat with the engine off. This has the setting in the MMI and usually a remote control also. Retrofitting this to warm up with the engine off isn't particularly hard. You can enable the controls in the MMI with vagcom, but without the pump to move the water round the heater will just boil the water and shut itself down due to overheating.
Jon, I would assume, has a standard UK spec car, with no Aux heating, but will have the Webasto heater as standard, and it is this which is over-running.
Interestingly, they often fail to work, but over running is not something I've heard of. Either way, there's no MMI config to it (unless someone has been fiddling).
So, I guess the heater thinks the coolant is below desired temperature which is why it is still running making a sensor a reasonable bet. You've not mentioned, so I assume the car is getting up to and maintaining 90 on the temp gauge ?
Vagcom should be able to tell you a lot, and ever if there are no errors, the measuring blocks should be able to tell you what temperature the webasto thinks the coolant is at....
