Originally Posted by awolfinsheepsclothes
Hi it seems to be loosing pressure and slipping intermittently possibly the same o ring as syncros8 it's the same FBG code and the Milage is 176k
I would put money on that being the o-ring & bearing. They're easy to change and the parts are <£100. I did it as a precaution while my drivetrain was out for the new engine. I would suggest parking it up until you can get it apart to have a look since it sounds like it might be recoverable now, but if the clutch packs start slipping they will burn out very quickly and then its full rebuild time. Get a sample of the oil - if it's grey/brown and a bit fishy it's rescueable. If its dark brown and smells burnt then its too late.
I might not like doing it but I have access to facilities and a great group of friends. And if I can't do something then normally I know somebody who can.
That's a very good start
Getting the gearbox out of & back in the car is the hardest part. The rest is easy once it's on the bench.
