Old 9th May 2017, 08:14 AM
HPsauce/tonupkid - Just wondering if you're listening to the wrong noise. There is a noise at the very start and around the 10 second mark (like crackling from a LP). Ignore that, as that was from the GoPro resting on my left foot. I get what you mean by something loose causing it, but it doesn't alter with speed (which I would have expected). The only change in tone is when you take your foot off the accelerator and the noise stops. I was doing about 30mph when I did that video, but it would sound the exact same at 60mph..
Pretty sure I got the right one, when you put your foot down it's there. Suggested to me that very slight movement of engine/drive/whatever under load was releasing something metallic and dry. Constant noise as you said so not rotating, hence my suggestion.
And aren't manifold flaps mainly rev-related, though obviously the vacuum driving it is somewhat throttle-related. You could check that by manually overriding gears.
