Originally Posted by M-A8
If your gearbox is faultless than it's only recommended to just replace oil like for like with new filter, same spec oil gearbox was filled in at the factory.
I know engine is different, but would you not change the engine oil if it's running faultlessly??
ZF clearly states to replace the oil either after 100,000 or 7 years, which ever is first.
Good point. I do change my oil within every 10k miles. Which is probably overkill with 507.
I just have a niggle, I think I’ve read something somewhere of faults after fluid change with gearboxes.
Edit: I know ZF make them, but don’t Audi et al still suggest they’re ‘sealed for life’?
2007 Mini Cooper S R56
