OK, I've been and looked at the relays and taken a picture (attached).
There are 3 sets, the lower ones are out of the picture and the upper ones are mostly hidden by a big flap of heavy felt material but just in view.
The top row corresponds to the layout that both Sean and I found, with a row of fuses below the relays.
I think the leftmost one (204, 40A) is the one I'm after. I think the part number is 431 951 253H.
Not sure what the righthand one (373, 40A) is in position 5 or the two narrow green items in 3 and 4. There's another 373 to the right of that in position 6 out of shot.
I didn't pull the 204 as it's socket felt insecure and I though I'd ask for opinions first. Currently the car starts in P and I haven't touched the gear stick.
Sadly I found another problem when gaining access, water under the carpets...
The scuttle is actually dry so this must be the aircon drains again. Another job for the list.
