View Single Post
  #313
Old 31st January 2020, 01:55 PM
Cheers Mark, sounds similar enough to my experience to make the same cause/fix plausible.
There's a hesitation for a few seconds, like the ECU 'thinks' you still have your foot on the brake, which I suspect is the contact sticking.
Though given the way the switch operates, with the released brake pedal arm forcing the spindle of the switch in to disconnect the brake light circuit, it's probably something slightly more complex than contacts sticking.
I'm reluctant to swap the switch in winter weather, easy though that may be in isolation. I don't have a garage/workshop to work in and there's a lot of extra equipment and wiring in and behind the drivers knee cubbyhole and panel that makes removing it non-trivial.
And some of that isn't working properly so if I do go in there I'll be committed to other jobs too: Xcarlink, Bluetooth, DVB-T tuner, receiver for reversing camera radio signal and relays to manage all that without draining the battery.
