I think the LEDs here are only in the main beam (separate bulb/reflector) so not an issue specifically.
Though updating the original Halogen dip/main bulbs would be, and that's already been done - so what happens at MOT time there?
I'm also a bit confused about 35W vs 55W ballasts, surely that a capacity issue (mainly current?) as the bulbs are designed to run at a certain voltage and should work as intended with the matching ballast.
It suggests more that the original 35W ballasts were deficient in some way if the light output improved with 55W ones but still using 35W bulbs.
