Old 20th February 2021, 07:14 PM
S81 S81 is offline
Default Replacement water pump
I've removed the water pump( shaft driven) as I thought the block o ring was weeping engine oil slightly ,(only seen it when I took sump off )but when I got it removed i discovered its actually leaking from a weep hole in the bottom of the pump ,i'm assuming theres a seal inside the pump that's leaking ,does anyone know who made the pumps for Audi it's stamped what looks like UT austria ,i'm going to change pump rather than refurb it as it's fairly nasty job to remove and even nastier to refit and don't want to have to do it a 2 nd time if refurb wasn't successful
Daily driver
Previously owned
Audi 80 1986 1.8 white
Audi 80 1990 2.0 red
Audi A4 1996 1.9 tdi green
Audi A6 1.9 tdi 2000 blue
Audi tt 225 2000 silver
Audi s8 d2 2002 fe grey
Audi a8 4.0 tdi d3 2006 black
Audi a8 3.0 tdi d3 2010 black
