On the bench - I never do control arms on the car. The principle should still work on the car, but you're swinging the hammer in an awkward direction of course.
Now ya tell me!!...lol
Indeed, no swing could be had with a hammer with the bearing housing on the car so I decided to take your lead and remove the whole assembly until I ran into the same problem again (only worse!) with the tie-rod ball-joint. The pinch bolt is seized solid and there doesn't even seem to be a bolt head to shear off to pull it through like I did with the other one. I had liked the idea of pulling out the whole assembly as the arms could then be torqued up to the referenced angle on the bench (if I read the manual correctly?) not to mention full access to my arch liner as I have a washer fluid leak issue to look at while I'm in there as well.
Originally Posted by S81
I had the same problem ,I used a trolley Jack and a small round bar to apply heavy upward pressure on the pin in the track Rod and then taped the housing gently and prolonged and pin eventually started to move ( it's not that easy to get the bar and Jack positioned to get the strong upward pressure as part of the suspension stops u from getting directly under it)(same as yourself I didn't want to damage the rubber boots ) ,I think I cleaned the corrosion out of the slit with a hack saw blade and sprayed penetration oil into it before hand as well ,when I went to the second side i just rung the head of the bolt right away and pulled it thu with the nut as it seemed to be the only thing that worked on mine
Thanks for that...I was ready to admit defeat and had the wheel back on with the intention of giving it to a professional, but I'll give it another go and see if I can get anywhere with the jack pressure. I did speak to a mechanic who told me he just hammers in a ball-joint fork and at the same time expands the slit in the alloy to get the arms out.
