Old 28th July 2021, 10:06 AM
jonnypym123 jonnypym123 is offline
From what your describing and as mentioned above sounds like a gasket, each 'throttle body' is attached to the manifold by 3 torx bolts give them a tighten and see what happens, oil residue is from pcv which is normal, just either gasket on throttle body gone or its loose
