Originally Posted by HPsauce
I found the plastic strip on the inside but it didn't want to slide.
It was quite loose at one end anyway and eventually just unclipped straight off; hopefully not too damaged to clip back on, otherwise it may need some adhesive or double-sided tape at the end of the job.
And looking at the strip it appears that "someone" in the past has just pressed it onto the mounting studs rather than sliding it, probably why it wasn't very secure, wouldn't slide and popped off easily.
Fortunately there's not much damage and I can probably ease the plastic channel back into it's proper shape and slide it back on securely in due course.
Part of it had quite a bit of dirt behind, where it hadn't been fixed fully flush against the door surface.
