Originally Posted by HPsauce
Thanks MJ I'll have a look when it stops raining!
How difficult/expensive is a bumper-off job and a new ram?
A replacement ram should be cheap from Prestige although its not particularly easy to replace on the driveway as the undertray needs to be disconnected at the front, and the parking sensors & headlight washers disconnected, then the bumper itself is obviously big and unwieldy.
I would suggest loosening the two big bolts and seeing it if will just slide back in to position first. If not then we can consider options for getting the bumper off
