The D2 does indeed have an anti-syphon filler neck. The best way I have found is to use the pump to push it all out for you, although that does mean you need to acquire a threaded adapter to connect to the fuel line at the front. I can't remember the thread sorry - M12x1.5 or something like that. I've got a hose tail of the right size attached to some ordinary braided hose so I can just hook it up and power up the pump. The advantage of using the pump is that it'll also empty the left hand side of the tank which other methods won't.
Alternatively, pop the level sender out of the pump assembly and you can syphon from there.
