This code usually happens because the brittle plastic pipe connecting the solenoid valve on top of the bank 2 fuel rail to the two SAI vacuum valves has perished and broken and so they aren't actuating on a cold start. The ECU can see they're not working by the readings from the secondary O2 sensors.
Its simple enough to fix by replacing the broken plastic pipe with standard 4mm braided vacuum hose and a T piece.
Well, she's spot on yet again (see photo below). And thanks to Sean as well for sending me the guide from Audipages.com. I only replaced the plastic pipes that Michaela mentioned as I couldn't get to the vacuum reservoirs without major (for me) dismantling work.
Started it up and the engine management light went away without even needing to clear it!
2002 Final Edition S8. Ebony black with Silver Grey leather and myrtle wood trim. Current mods: solar sun roof, 20mm rear spacers, 15 mm on front, red brembo callipers, 6k headlights, rear view camera, engine remap, alloy dash dial rings, alloy navi rings, tt/phaeton pedal upgrade, (and custom matching foot rest) dension ipod interface & parrot hands free kit (both fully hidden), av input, tv in motion switched thro' PF switch in blanking plug right of steering column, Audi 'quattro' sill covers, repositioned centre console switches, radio clock, .
