Originally Posted by HPsauce
Adrian, if you spot this post, please do tell!
It’s been a good few years but from memory I gave up trying to fit it through the hatch and worked out the easiest way to remove the entire right boot side trim. From memory the black plastic around the lock catch has to come off first (there’s 3 plastic fixings from memory to avoid breaking), which then allows you to swivel the side trim out of the way without actually removing it from further into the boot. Gives you a nice big slot to fit the battery in then
