*** SEE LATER POST - BELOW IS NONSENSE YOU WANT TO BE WORKING ON THE ROOF WITH IT OUT OF THE CAR NOT IN THE CAR. ROOF ONLY GOES INSIDE THE VEHICLE ONCE IT IS READY TO FIT ***
Fantastic. The roof I bought was disconnected in the closed position whereas mine was disconnected in the open position. So I removed the motor from the old roof, plugged it all in and set the control to full closed.
The hope is that that will work when I fit the motor to the new roof. I think I’ll set it on a big piece of card in the car with the seats reclined flat, then plug it in, check operation and I think it would be best to fit it in an open position. Not sure on that I suppose it depends how precisely it lines up.
I did read somewhere there is a set up procedure for this but I can’t find the info now!
Reason: Bad procedure.
