Old 7th April 2023, 04:35 PM
All those engine components are run from the same fuse - S117 'control element fuse' which is a yellow 20A in the ECU box. I'd suggest replacing the fuse and giving the fuse holder terminals a spray with contact cleaner / WD40. Its likely there is some corrosion or grot on the terminals from when it was damp in there.
I have a box of hazard switches if you want one posting, or are passing to pick one up
Checked in the ECU box and all fuses were in a state of corrosion. The 20A fell apart after tugging it out! Liberal amounts of contact cleaner and all fuses replaced.
I noticed some condensation to the underside of the ECU box lid. You would think there must be some way of ventilating this box to alleviate this?
Crash implausible error has disappeared.
All intermittent have gone.
On to the Airbag issue.
Paul
Gosport UK
________________________
Audi S8 2002 FE Avus Silver / Extended Red Leather.
Daily Driver: BMW 3 series GT - Just more practical for my camping trips!
