Hi. I should have noticed this before, weather not being warm enough, but my HVAC unit or the AC bit is not blowing ice cold.
I have:
Checked fuses - no issues
Run a scan on the HVAC unit - No codes present
Visual inspection - all seems good - no loose connections
Cycled through the options, switching ECON on or off does not not seem to indicate any changes to the compressor. I checked the compressor fuse (drivers footwell) and that is OK. Are there any other connections I should be looking at?
