As of right now there isn't any water leaking problems as the tape for the Botang hole is holding up as I washed the old girl yesterday and didn't see any water inside.
She cleaned up nicely.
I was looking to see if there is a way to only unbolt the exhaust manifolds so I can remove the cylinder heads to do this valve spring job.
This is what the exhaust manifold studs and nuts currently look like
I'm just losing any motivation to work on this car.
