Originally Posted by steamship
I didn't even know self-levelling was on the D3.
Adding to your point about stiff suspension, do you have Towing mode enabled, as I've seen suggestions that that can attribute to the harshness? Have seen multiple references to hard suspension both on the D3 and D4, but no concrete solution to it anywhere on it's cause/resolution.
Don’t think I sawing tow mode enabled but will double check. The suspension doesn’t seem hard, it’s super wallowy n feels a bit floaty at times, crashes about over holes bumps that I’d normally have had no issue with in the d3. Both d3 and d4 are sport models by the way
2014 D4, FL 3.0tdi, phantom black, sport exec lwb
1997 D2 PF 4.2q, silver, Sport on roughly 90k and counting….
1990 2.3 20v 7a Coupe Quattro
