01274 - Air Flow Flap Positioning Motor (V71): Faulty
Possible Causes
Wiring/Connectors from/to Air Flow Flap Positioning Motor (V71) faulty
Positioning Air Flow Flap Positioning Motor (V71) blocked
Positioning Air Flow Flap Positioning Motor (V71) faulty
Possible Solutions
Check Air Flow Flap Positioning Motor (V71)
See Measuring Value Blocks (MVB)
Perform Output Test
Perform Basic Setting
Check/Repair Wiring and Connectors
Try running basic settings in the first instance, and see if the fault reappears. If lucky it will resolve itself, but if not will be a case of accessing it to check if the motor has failed or if there's a related mechanical fault in a linkage somewhere
