It's working!
Brake System Removing and installing handbrake cables
Removing
- ‒ Remove both rear wheels.
- ‒ Release handbrake.
- ‒ Remove rear exhaust on quattro vehicles.
=> 6-cylinder Engine, Mechanical Components; Repair group 26
=> 8-cylinder Engine, Mechanical Components; Repair group 26
- ‒ Remove centre heat-insulation panels.
Note:
Mark the position at which the propshaft is bolted to the rear differential.
- ‒ → Unscrew the bolts attaching the propshaft to the rear differential -1-.
- ‒ Remove the heat insulation panel in the propshaft tunnel -arrow-.
- ‒ → Loosen the adjusting nut for the handbrake cable using special tool -3343-.
- ‒ Take the handbrake cables off the compensating bar.
- ‒ Pull out the retaining springs -arrow- from the handbrake cables.
- ‒ → Unhook the handbrake cable -3- from the brake caliper.
- ‒ Press out the spring clip -2- and pull out the handbrake cable to the rear.
Notes:
- ◆ On FWD vehicles the open end of the spring clip -2- should point towards the brake.
- ◆ Do not loosen bolt -1-.
- ‒ → Release retainer -1- and pull the handbrake cable out to the rear through the guide -2-.
- ‒ Release attachments -4- and -5- far enough to allow the handbrake cable to be taken out.
- ‒ Pull the handbrake cable out to the rear through the guide -3-.
Pay special attention to the following on installation:
- ‒ Propshaft to rear differential, 55 Nm.
Remove any residue of microencapsulated adhesive from the internal threads of the rear differential.
- ‒ Install and align the exhaust system.
- ‒ Adjusting handbrake=> Page 46-76
