Originally Posted by notorious
Ian,
Have you moved to renovated house? I wonder if you're happy with internal wall insulation.
Looking at your photos I see 'aluminium' foil on top of insulation material, which makes walls non-permeable for internal moisture.
No problems of with excessive moisture in the house?
He wouldnt have a problem with that, hes got a heat recovery ventilation system that changes the air every 2 hours so moisture is extracted / condensed away and the air replaced with air from outside with a lower moisture content
