If those are the right fitment then they look better than what was available when I was looking a year or so ago. The ones that are a flat board with LEDs on 2 sides look cack as you can see the sidelight bulb though the lens if you look closely.
Pull a bulb (they do literally pull out and you then remove the plug) and check its markings to be safe.
Doddle to fit - tonnes of space!
Did you replace like for like on the main xenon bulbs? The beam pattern can be poor with the wrong ones fitted
