Old 2nd February 2013, 11:45 AM
Yes it can be done, though some bulbs (courtesy, map and vanity IIRC) are different.
There's also a polarity issue at the front which I'll add some details on when I remember what it was.
Everything else was pretty straightforwards.
Edit: It was the front centre map lights which are, IIRC BA9s but are the wrong polarity for LED's.
The glovebox is also a BA9s and was the wrong polarity, but if you take the glovebox out you can swap the spade terminals over on the bulbholder to fix that.
I suspect FL is the same, haven't looked at it yet.
I bought some small panels with a selection of adapters and reversible connectors on the leads and stuck them in with double-sided pads.
Not very elegant though. Something like this:
