  #37
Old 18th September 2013, 08:24 PM
Well my trims have arrived I've ordered the lower bits to match from TPS in Swing but they're on back order from Germany so will probably not arrive till the back end of next week. I might do a cheeky fit of the drivers one and put the purple lower bit back in.
What my door looks like at the moment - the front ones are both quite badly marked from nails/rings etc and even if I wanted to buy replacement purple ones, I can't as they're NLA.
It's also an interesting experiment to see whether the grey finish will break up the purple in a positive way.
Some really rubbish pics of the new trims. These are actually Dark Myrtle over Swing (the colour of the upper door handle area). ID'ing the right trim option is a nightmare - in Etka you need to identify the PR code for the colour of trim that you want to fit (5MW for dark myrtle) and from that work out which of the available options you want. The door trims are listed as Myrtle with a secondary colour to match the plastic underneath (soul, swing, jazz, tango). Also worth noting that my handbook states my interior is Platinum (WF) BUT there is still a mix of Platinum (light) and Swing (dark) grey depending on the surface.
Once I've fitted these I'll post the details in their own thread but thought it was relevant here
ID:	6688   Click image for larger version
ID:	6689   Click image for larger version
ID:	6690   Click image for larger version
ID:	6691   Click image for larger version
ID:	6692   Click image for larger version
ID:	6693   Click image for larger version
