Torque settings are:
42Nm for gearbox support to gearbox and support to gearbox mounting
40Nm for gearbox mounting to subframe bolts
ElsaWIN suggests you don't touch the front subframe mounts but can drop the rears 10cm without issue and no need to check alignment after
