Took a bit of time but I finally got round to doing it.
Trim removed.
Alloy backing, plastic bits and chrome bits removed.
Trim all ready for him to paint.
I changed my mind on Piano Black. Was suggested something a little bit different but apparently not to far away from piano black.
Should be ready this weekend. We will see what happens.
I never thought the trims would be some form of wood topper, then a alloy/steel backing bolted on to a alloy frame.
They seemed so strong with all that framework on.
Also found out that if the middle vents are unplugged you can't go in to the AC setup menu. It does nothing.
[center]
06 3.0TDI Quattro:
Options:
