Originally Posted by mik15
is it easy to simply run the cable from the back of RNS-D into the glovebox without having to dismantle half of the car?
Of course, I did that for my first install of my XcarLink which just sat in the glovebox. I'm in the (rather drawn-out) process of relocating it to the cubby hole by the drivers knees along with some other kit.
It's a bit tight to feed it through over the top of the trim at the right of the glovebox, but not that difficult with the RNS popped out so you can reach both sides. Probably easier if you take the glovebox out first which is a quick job, though I didn't bother for that (though I did to change the light bulb which is almost impossible otherwise).
Biggest problem I found was that when the glovebox closes it squashes the cable between the right edge and the roof.
