Originally Posted by moltuae
Nice work!
Did you push the patch piece in through the hole and then poke something around inside to lay it flat against the back, or did you somehow manage to get to the back of the leather to place it over the hole?
Pushed the patch through the hole and used a supplied wooden spatula to flatten it and position it. I put a small mark in the middle of the patch first so I knew I had the patch centred on the hole
