Earlier in this thread, as I've just rediscovered, Jim asked:
Originally Posted by The_Laird
can other similar sirens be used as well, such as 1K0 951 605C? It looks the same, comes from the VAG stable and has the same 3 pin fitting, but I don't really understand what the prefix and suffix numbers/letters mean.
He also acquired a rev D which, like my rev C, didn't work at all.
My 'experimental' approach to fixing the alarm horn (try one from another VAG car) took a step backwards yesterday The alarm from a 2007 Passat arrived in the post (part nummber IK0 951 605D), so I fitted it last night. Same 3-pin connection and, with the little captive bolt swapped for the one off the original horn, it fitted a treat (slightly smaller).
So, set off the alarm and....nothing!
I've done a bit of soldering tonight on my extra loom section and in daylight tomorrow should know whether it is purely a changeover of the Comms and GND connectors or there is something more subtle in the interaction with the control unit between the different versions. Fingers crossed.
