  #64
Old 18th April 2015, 09:02 AM
I think I've found one possible cause for the fitting issues of the centre caps.
Studying pictures online (of my cheap Chinese ones and similar) vs the genuine set I have just acquired, the four retaining lugs that are pushed out by the spring are subtly different.
The OEM ones have a vertical "slab" that is 10mm wide and 2mm deep with a couple of "buttresses" at the bottom. And of course the two-way sloping wedge section at the top with the spring pressing on the back.
The copies have the same slab, with buttresses, but part way up thicken to maybe 3.5mm and that extra thickness continues in the "wedge".
This makes them overall maybe 3mm larger in diameter where the lugs have to penetrate the hole in the centre of the wheel and of course much less flexible.
Enough to make it difficult or impossible, unless (as I have) you use smaller/weaker spring rings and bend each of the lugs in a bit.
I'll try to attach some pictures to show the difference.
Taken from different angles and just "snipped" from t'internet but the difference is pretty clear. The OEM ones have slimmer, straighter lugs and the copies are just too bulky.
ID:	10502   Click image for larger version
