Page 164 mate, says to select Basic settings, then group 002.
At that point you will most likely need to press the on/off/next button.
So go into module 3 ABS, then basic setting, select group 002,press the on/off/next button.
Pump should run for ten seconds, only do a max of three times then leave the unit to cool for a while.
