Originally Posted by triumph2.5pi
Could the mileage on that cluster then be reprogrammed to match the old one?
Yes, mileage can be adjusted. It's stored in an EEPROM within the cluster. It can be read / write in place with a suitable clip and
'tool'
Is there anything I would need to know in order to make this work?
I think you will need to know what IMMO generation you have in the D2 (I'm thinking it's Gen3 ??) and to have PIN's from both your cluster and the replacement cluster for the swap.
