Old 20th September 2018, 04:21 PM
MattyV8's Avatar
MattyV8 MattyV8 is offline
Default Air Suspension Gone Wierd
Got an issue with the suspension settings - I had to drive through quite a few deep puddles with the torrential rain in Stoke so set the suspension to lift. All was fine. Got home and stopped then tried to put it into comfort mode but the lift option was greyed out and it wouldnt select any other mode. I left it for 5 minutes, started it up and the lift was now not greyed out so I tried selecting another option but no arrow lit up. If I select lift the up arrow is highlighted but when I click any other option no down arrow appears.
I have attached a picture of each side which is how it is sitting currently. Wondering if it is still in lift mode, how come when I press lift the up arrow is highlighted?
Also the passenger front side sits higher than all other sides.
Hoping I having damaged the pump by driving through puddles..
2006 Audi A8 4.2tdi Sport
