Its an annoyingly misunderstood process.
The 'coding' process is simply used to tell the cars battery management module that you have a brand new, fully charged battery, and for it to reset its counters.
The D3, Q7 4L A6 C6 etc all started the new trend of active battery management where they will monitor power in and out of the battery to determine what systems should be powered on or not. For example, leave your car a while and the keyless entry will disable to save power so you can start it. Advanced stages would disable interior lighting when you open the doors etc.
I see it time and time again where people have electrical gremlins, fit a new battery without coding, and then shortly afterwards, still have electrical gremlins.
They're not gremlins, its just because the car thinks the battery is flat, when you think it isn't.
So, will not coding break it - No. But, I personally wouldn't recommend it as it will cause issues, more likely in winter when drain is higher.
For parts enquiries and
Forum User Administration please contact customer services directly, not me
enquiry@a8parts.co.uk, www.a8parts.co.uk, or call
01642 783537
2007 4.2 Tdi Q7, 2006 S4 Cab Silver, 2010 RS6 Saloon Black
, 2007 TT Roadster,
