Originally Posted by A8Jas
Thanks Sloss, great info. So I'm thinking to just do the DRLs as the sidelights are rarely used, are there any plug n play 1156 LEDs with the resistors in place?
The 1156 with resistors I have seen are not as bright, maybe 120 lumens.
The brightest I have seen without are 450-480 lumens.
If you can be bothered, you can swap the sidelight and DRL pins round in the headlamp connector and recode for LED DRL, then the DRL is used for sidelight at reduced brightness and dims when indicating.
