Thread: MOT failure
Old 11th August 2020, 09:15 AM
They probably mean the rear subframe, which is pretty common. Unfortunately its a big chunk of work to remove it and re-paint.
Rear brake pads are the same as on anything else of that age and very simple to do, as long as the discs are in decent condition. Its worth being aware that they may find problems with the seals on the rear calipers as they fail often, especially when fully extended due to worn pads.
